12-23-2016 05:56 AM
I update an application builded with .Net3.5/C# wich uses DAQmx 14.1.40; i do this software update using VS2015 and .Net 4.6. In the old projet of my application, i used references to NationalInstruments.Common.dll and NationalInstruments.DAQmx.dll. Unfortunately, installing DAQmx 16.0.1 installs NationalInstruments.Common.dll on my disk, but NOT NationalInstruments.DAQmx.dll.
Some one can tell what dll shall i use in place of NationalInstruments.DAQmx.dll, or if i must install other things?
Thanks i advance
Pascal
12-26-2016 08:28 AM
Hi Pascal,
Thank you for posting on the NI Forum. You should have a look at the following topics that might help you :
http://forums.ni.com/ni/board/crawl_message?board.id=232&message.id=14741
http://forums.ni.com/ni/board/crawl_message?board.id=232&message.id=3866
Best Regards,
12-28-2016 01:11 PM
thanks for your reply.
As suggested in your links, i've executed the installer again in personnalized mode (as during the first install), but this time i checked that supports for .net languages are selected, which is not the default settings
. Strangely, there are support for .net 4.0, 4.5, 4.5.1, but not for .net 4.6.
Other thing, in a x64 project, i just added a reference to NationalInstruments.DAQmx.dll, and when VS builds the project, it also adds in the project solution folder a copy of NationalInstruments.Common.dll (like with old versions) but also of NationalInstruments.MStudioCLM.dll and NationalInstruments.NiLmClientDLL.dll.
But this works which is the principal thing.
best regards
Pascal
