usb 6008 generate 5v dc voltage
hi, how can i generate a 5v dc voltage with the usb 6008 data aquisition.
Message 1 of 16
(9,607 Views)
There are write functions in DAQmx. If you want more details, it would help if you mentioned the programming language you are using.
Message 2 of 16
(9,605 Views)
i want to made an application with labview 8.0.
Message 3 of 16
(9,596 Views)
Put a DAQ Assistant on the block diagr Configure it like the picture below and then wire a constant to the data input. There are also shipping examples of DAQmx with analog output.
Message 4 of 16
(9,588 Views)
Hi Dennis, I'm new to LabView/DAQ - and, I have the same issue, I want to generate a continuous +5V DC voltage from USB PXI6259 by LabView 8.2. I have tried your suggestion but can't generated it (is the block diagram the same as in the picture here )? Please help me with this, thank you Hai Linh
Message 5 of 16
(9,335 Views)
Hi, I'm using Gen Voltage update and be able to generate a DC voltage - but no matter how high the value I have tried (set to 5V, 6V, 9V...) the output maximum is only 3.9V ~ 4.1V. This value can't help me to power my IC 😞
Message 6 of 16
(9,320 Views)
What do you mean by "generate"?
If you just need 5V for an external circuit (and don't need to control the voltage), there is a 5V, 200mA max supply available on the USB-6008 terminals. This is on constantly. Just connect to it and to a ground terminal.
If you have to control the voltage, there are several choices, depending on your requirements.
You will have to know how much current you need to supply, as well as the minimum voltage you can use to power your circuit.
If you just need to turn it on or off, and require relatively little current, you can use a digital output. These are open-drain outputs that have a 4.7K resistor to the 5V supply. So if you can use anything over (say) 4.7V, then you can power a circuit that takes up to (5-4.7)/4700 = 64µA. Just turn the output OFF to turn your external circuit ON.
If you just need to turn it on or off, but you need more than that relatively small amount of current, you can use a digital output to control a p-channel FET: connect the source of the FET to the +5V power terminal on the USB-6008, the gate of the FET to a digital output, and the drain of the FET to your load (with the return from your load connected to the ground terminal on the USB-6008, of course).
If you have to control the voltage to something other than "ON" or "OFF", you could use an analog output. As described in the User Guide for the USB-6008/6009, there are certain
limitations to the drive capability of the analog outputs. They are capable of providing up to 5mA, but they have a 50Ω output impedance, which means that if you try to get 5mA out of them, they will droop from +5V down to (5 - (0.005 * 50)) = 4.75V.
If you have to have control AND high current AND require a full 5V, you will have to use an external supply and an external transistor or other buffer to increase the output capability of the analog outputs.
Message 7 of 16
(9,313 Views)
Is it possible to generate +5 V each through the 12 digital outputs?
I want to get eight +5 V and a ground. This is for an on/off function. The machine to which I'm connecting the USB 6008 will toggle between on and off with respective to the polarity change, ie from +5 to ground and vice verca.....
Please help me.........
Message 8 of 16
(8,946 Views)
Yes, each digital line can output a TTL signal. You should have gotten a user guide with the device bbut you can also get if from here.
Message 9 of 16
(8,943 Views)
Thank you so much for the reply.
I'm using LabVIEW 8.5 Developers suite and I'm new to labview. Could you help me to get an idea about designing a program in order to change the voltage? I want to control[ON/OFF] eight machines at a time. The ON/OFF can be acheived by changing the voltage between +5V and ground.
Message 10 of 16
(8,939 Views)
