usb 6008 magnetic
I am using USB 6008-6009 DAQ, the problem is that there is strong magnetic field close to the device (about 5 meters away from the source of the field), and it seems that because of it the device is not working (because the LCD of the computer was affected by it). Is there a way to avoid the magnetic interference in this case?
With many thanks in advance
(2,882 Views)
1. Move your DAQ system away from the MF.  2. Five tips to reduce measurement noise. 3. Noise considerations.
(2,858 Views)
