usb 6009 is not recognized in max with Windows7 x64
Hi to all the Comunity and I apologize for some possible errors with my english.
I have a problem in the installation of an USB-6009 device in Windows7 x64.
I have already downloaded and installed the last NI-DAQmx 9.0.2 and the device appear correctly installed on the OS in the Device Manager.
The problem is in the MAX that is not able to detect the device.
I have try also to change USB door and to reinstall all the package NI-DAQmx, but the device is always not detected in the MAX.
Any other suggestion are well appreciated to solve this problem
Thanks to all
Message 1 of 9
(8,417 Views)
Accepted by topic author Maverjk
Hi Maverjk,
I have a couple a question for you to try to resolve your problem.
* Have you download the DAQmx base or full package?
* Can you try to install your USB-6009 on an other PC and tell me if it works?
Otherwise you can  try to repair your MAX database: read this documents.
Ciao!
______________________
Simone S.
Academic Field Engineer - Med Region
Message 2 of 9
(8,394 Views)
Hi sisu84
The DAQmx  is the  full package and the device is completely working on another PC.
However i have try to repair the database as you have suggest and now the problem is solved 😉
Thank you so much.
Grazie di tutto. Smiley Happy
Message 3 of 9
(8,389 Views)
Hi
My NI USB-6009 is not recognized by any of netbooks I got neither eeepc 900 with a intel atom processor and a windowsXP OS or with UBUNU nor Packard bell's dot.m  with an ATHLON processor with a windows vista OS or UBUNTO. I mean no first time installation program  ran when I pug it to the net book but this usb is working perfect on my dell notebook or on my desktop with windows xp.
Message 4 of 9
(8,203 Views)
Hi
I think that to make possible that your USB device will work fine you have to install the DAQmx package compatible with your OS.
The DAQmx is possible to download from the NI website. You have just do find it.
Hope that this can be helpful for you.
Message 5 of 9
(8,182 Views)
Hello every body
First of all I ve download NiDQ max ( about 1GB) and after installing it everything is ok even on old versions of netbooks the only problem is downloading of 1GB with slowline 😄
Thanks for your help
But there is one more question I wana send an sms via my cellphone. This is a part of remote monitoring system measuring by Ni USB6009 and  creating a text file which gathering data then sending a part of these data in certain periods of time by sms as a condition of my system.
 Is there way to do so with labview ( I know there are some works by C++, # or AT commands )?
Message 6 of 9
(8,125 Views)
Hi
I think that you should open another post for this kind of question if there is nothing already treat in the forum.
Message 7 of 9
(8,123 Views)
hi evrybody
iahve tested usb6009 on some systems like desktop, dell laptop, acer netbook with an atom prcossor with installin NIDAQ everthing is ok but i have a problem with asus eeepc 900 ( intel atom processor and WINXP OS ) i have installed NIDAQ872 even the labview engin82 but the system couldn t recognize the usb6009 nothing happens when i plug it only the green light on the usb6009 device start to twinkle.
i have to work with this eeepc and usb6009
any help would be apritiated
Message 8 of 9
(7,651 Views)
Hi thisisit,
I suggest that you try to connect USB-6009 to PC through an USB hub with a power supply.
Tell me more if you resolve your issue.
Ciao!
Simone S.
Message 9 of 9
(7,619 Views)
