usb 6009 measurements resistence
There are two techniques for measuring resistance! Current source and another source of voltage. `How to do this using the DAQ 6009?
(2,946 Views)
Just as you said in your post, for basic resistor test, you will need a constant current source output and measure the voltage or you will need a constant voltage source and measure the current.
So you can not do the resistor test only using a 6009, you should provide a external constant current source, and use the 6009 to acquire the voltage.
Message Edited by NIhuyu on 02-24-2010 12:41 AM
Best Regards
Hu Yu
(2,935 Views)
