usb daq not detected
I have some issues recently with my USB 6008 DAQ. The DAQ is not detected anymore on windows.
It seems windows doesn't notice at all when I connect it.
I have checked:
- On the device manager there is no any exclamation point.
- I tried with a little sofware from microsoft: USB viewer to connect it and really nothing is detected.
- I have also tried on another computer, same results, no detection...
-The LED is not blinking as it used to but behind the port, the multimeter measures a voltage of 1500mV.
-The DAQmx drivers and DAQ drivers are up-to-date.
-The NI Device Loader, Configuration Manager, PXI Resource Manager and Service Locator are all set to automatic in services.msc
I am currently using LabVIEW 2009 on WIndows 7 (32-bit).
Would you have an idea where the problem could come from?
(3,483 Views)
I am having a similar problem - in "devices & interfaces: measurement and automation explorer" there is no option for NI-DAQmx devices (it looks like it is not being detected), and in LabView Signal Express for DAQ (2.5.1), it is saying that no supported devices are found when I try to enter an analog signal.
I have a USB 6008 and have plugged in an amemometer for wind measurement.
- I am running windows 7 (x64)
- All drivers seem up to date
- my USB light is flashing on/off at a steady pace on the DAQ device
- I see the data acquisition device in device manager
Forgive me if I am a newbie, but what is wrong?  Any idea?
(3,471 Views)
Hi I have similar issues with my DAQ device. I m using Windows 7 (32-bit). Labview is running fine but I also need to use DAQ device 6008. When I try to use DAQ Assistant to acquire signal I just get message that there is no supported device. My device is blicking when is plugged . Any advice what to do?
I m also new in this world then when someone will know please try to explain it in simple language.
Thank you
(3,450 Views)
