03-01-2007 12:52 PM
03-03-2007 04:09 PM
Hello Stemac,
If you already have a signal generated in LabVIEW, it should be fairly easy to generate the analog output on your card. Have you tried using the DAQ assistant which is located in the functions palette on the block diagram under Measurement I/O > DAQmx Data Acquisition. You can configure the DAQ Assistant to output the waveform in the way you want it (See attached). You can then just wire the signal that you already have in LabVIEW into the data input of the DAQ Assistant.
Raajit L
