usb6211 triggering
Hi, I am doing an internship in a laboratory. I am supposed to use the CARD USB 62-11 to trigger a camera  POINT grey FLEA3 USB3,0. My project consist actually of taking a picture every T/10 of a sinus wave and to calulate the number of pxel and the lightening.. I am not really familiar with DAQmx as it's the first time that I use it so I am having a probem with to make the program of the triggering.. I made already this program allowing you to alculate the number of pixel and the lightening.. but I am stucked in the triggering part... You will find attached my program, all suggestion or öodification in the program are welcomed
(4,884 Views)
I think what you need it is good documentations and good examples, find given below 2 useful links :
1) https://www.ni.com/docs/en-US/bundle/371007b/resource/371007b.pdf
2) http://www.ni.com/example/6712/en/
Dasso
(4,845 Views)
Hi , I am working with marwa who possted this question on the same project , i alredy triggered the camera with an example of image acquisition and a DAQ , you will find attached the program. My problem now is that i want to change the mode of acquisition , i want to use the mode 14 for example , but i have no idears how to use another mode than the mode 0.
Any idear will be appreciated .
Thanks 🙂
(4,813 Views)
here are the different modes ( i want to use mode 14 to get a max frame rate )
https://www.ptgrey.com/KB/10250
(4,811 Views)
Did you try changing the mode from MAX?
(4,724 Views)
