usb6251 counter samples not acquired
When I read the lastest readme for DAQmx 9.2.3 release, I noticed there is one known error "Samples Not Acquired on NI 660x or NI 6624 Devices. When using pulse width, semi-period or two-edge separation buffered measurements with the NI 660x and NI 6624 on counters 0 and 1, some samples may not be acquired under certain circumstances". Actually when I was using USB-6251 to measure pulse period using counter 0 or counter 1, similar problem occured too. At that time I used buffered counter sampling triggered by digital rising edge and occasionally the available counter samples remains zero or stopped at some uncompleted sample number. I thought it might be the trigger problem. Is it possible the USB6251 counter has the same problem as stated in the readme?
(3,339 Views)
would anyone please comment on this?
(2,760 Views)
