use USB 6009 control microcontroller by RF
how are you, hope all who read my question are in good health n good mood
i am doing a proposal for my research for school n i hope to make it as my final year project as well.
my idea is use a labview to control the micro controller, i will design a robot come out. but the problem is
i dunwan to use the controller to control, but through the computer. so i think that use RF.
can i use put 2 in the robot 1 is Transmit and another is RF. at the other device DAQ it also have the transmit n Reciver.
one pair is use to control the microcontroller and antoher is use to collect the data such as from the webcam, the voltage level , the movement of the robot.
the Voltage is use the solar system power, and will charge the battery- so the voltage level is to observe the batter voltage level.
(3,155 Views)
I am not sure if I quite understand your application.  Just so that I understand better, you are trying to control a microcontroller which is in turn controlling a robot.  How are you planning to use RF to control the microcontroller?
Have you though of what kind of hardware you are looking for?  Are you looking for RF transmitters and receivers from National Instruments?  You mentioned 6009, is this the only hardware that you have currently?
With the 6009 you can read/output slow analog signals and some software timed digital signals.  Are you trying to control the microcontroller through these signals?  I am not sure I understand where and how you are planning to use RF signals.
Thank you.  Looking forward to hearing from you.
Raajit L
(3,136 Views)
