use loadlibrary with matlab
Hi, I've downloaded software NIDAQmx and I want call the functions with Matlab.
I've done the next:
loadlibrary('NIDAQmx.lib','NIDAQmx.h')
Warning: Warnings messages were produced while parsing.  Check the functions youintend to use for correctness.  Warning text can be viewed using:[notfound,warnings]=loadlibrary(...)
> In loadlibrary at 394??? Error using ==> loadlibrary at 474There was an error loading the library "C:\Archivos de programa\National Instruments\NI-DAQ\DAQmxANSI C Dev\include\NIDAQmx.lib"C:\Archivos de programa\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include\NIDAQmx.lib no es unaaplicación Win32 válida.
Caused by:    Error using ==> loaddefinedlibrary    C:\Archivos de programa\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include\NIDAQmx.lib no es    una aplicación Win32 válida.
I think that the problem is that I haven't a .dll file, only I have a .lib one. Can somebody help me with my problem? Anybody known if exist another method to use Nidaqmx's function from Matlab (moreover Toolbox Data Acquisition).
(3,807 Views)
Hello ManoloAS I think this is more a MathWorks issue, but following links can help you to fix this problem: http://forums.ni.com/t5/Multifunction-DAQ/Use-M-Series-cards-with-DAQmx-in-Matlab/m-p/185232 http://www.jr-worldwi.de/work/matlab/ http://www.codeproject.com/KB/DLL/MatlabGenericDll.aspx In short, it looks like you must call the dynamic library instead of the static.
(3,757 Views)
Hello ManoloAS
(3,756 Views)
