using DAQPad-6016 with LW/CVI 6.0
There doesn't seem to be any utilities for DAQPad-6016 in the CVI 6.0 library.  Where can I find the lib routines to configure and operate this module?  Tx
(2,727 Views)
Hello DMBS,
It looks like you are using the DAQPad-6016, which is supported by the DAQmx driver. The lastest driver for this device can be downloaded from our website at the following link:
NI-DAQmx Version 8.5 for Windows 2000/Vista x64/Vista x86/XP
Upon installation there are  help files that you can select to install with your driver that will give you information on how to program in C with the DAQmx Driver. The resource you are looking for is the DAQmx C Reference Help.
Here are some additional resources to get you started:
NI-DAQmx Installed Documentation
Using NI-DAQmx in Text Based Programming Environments
I hope this infomation helps. Take a look at these resources and if your questions isn't answer, please feel free to post here again.
Have a good day!
  Sandra T.
Applications Engineer | National Instruments
(2,714 Views)
