using NIDAQ under Matlab in DIFF, RSE & NRSE modes
Hi, I am trying to use a PCI 6221 NIDAQ under Matlab. I have tried with the NIDAQmx-tool for matlab, but I can not configure the inputs as Differential or single ended non referenced. I believe these routines treat all inputs as single ended ground referenced. Does anybody know how to change this setting?
I know that the new DAQ toolbox accepts the M family of multifunction boards but I do not have access to it...... I would really like to..... well, any suggestion will be wellcomed!!
Ernesto
(7,687 Views)
Good afternoon Pili,
I'm not positive about this, but it might be worth a shot.  You might be able to go into MAX and configure a Virtual Channel as Differential/RSE/NRSE.  Then, you might be able to call that virtual channel in your function call in MATLAB instead of "Dev1/ai0".  You might be able to call "MyChannel1", or whatever!
Again, I'm not positive.  But, I think that should work!
Cheers!
(7,674 Views)
Thank you Jeffrey, but it seems that NIDAQmx-tool does not accept virtual channels. I think the only solution for me is the new instrument toolbox from Mathworks.
Pili
(7,651 Views)
I'm having the same problem of not being able to specify single ended signals.
Is there a solution or work-around that has been successfully implemented?
Thank you.
Herwin
(6,954 Views)
Same issue... NRSE required, but unable to set from within MATLAB - without falling back to the C library.
Will try virtual channel.
(6,791 Views)
The Data Acquisition Toolbox in MATLAB allows you to set the Terminal Configuration using the property InputType on the channels.
http://www.mathworks.com/help/toolbox/daq/ref/channels.html - Using Session-based Interface in DAQ Toolbox
http://www.mathworks.com/help/toolbox/daq/ref/inputtype.html - Using Legacy Interface in DAQ Toolbox
Manisha
The MathWorks
(6,786 Views)
Excellent - that was exactly the command I was looking for.  Bizarrely we had actually used it 4 years ago, but had managed to forget in the interim.
(6,783 Views)
