valve control using actuator
Hi
I am trying to monitor a control rig via a mobile device.the rig consist of 1 inch diameter copper pipe through which air is passing at rate of 120 cubic litre per hour.I wish to control this flow of air proprtionaly using either acutator or a solenoid void.I came to know the there is no proptional solenoid valve avaialable .in that case my only option is an actuator.my question is which type of actuator can do this job and also can an actuator can be interface with labview using 7.1 if yes than which NI card should i use please do reply me.
Message 1 of 1
(2,785 Views)
