variable analog out
Hi all
I may be being obtuse here, but is it possible to generate a variable AO voltage without using buffers and waveforms, i.e. just send a single value to the Analog out as and when desired?
I have got it working by creating a waveform where the offset is the desired voltage level and the amplitude and frequency are zero, but it seems to be a long way round to achieve what's needed.  Also because I'm creating the AO voltage as a servo motor control signal I need to be able to have a rapid response to positional information.  I have found that the buffer size and sample rate that give the cycle/update time can cause crashes if the buffer is too small, and/or it seems, if the computer is otherwise occupied.
Any thoughts/ideas gratefully received
Season's Greetings to all
Andy
Using LV8.5  +  XP  +  PCI-6733 AO/CTR card
(3,444 Views)
Accepted by topic author andy_kennaugh
Have you looked at the DAQmx examples? There's one called Gen Voltage Update. The DAQmx Write is simply set to 1Ch 1Samp.
(3,442 Views)
Thanks.. must be getting old and blind.
(3,432 Views)
