vibration sensor gives no value after sometime
Hello
I am using NI PCI-6024E card for acquiring voltage using vibration sensor(KS80D).First when I start to  acquire values from Vibration sensor, it gives me data fbut after some reading it gives constant value from sensor.Then When i Reboot my computer and start to acquring the voltage it acquire again but same thing happen after some time it gives me constant value.I have attached two pictures for more understanding.I do not know what is the problem.It it problem with overloading or somthing else with sensor?Please give me solution about this problem
(3,603 Views)
Looks like a floating source with no bias path.
With differential measurement, add a 1Meg resistor from AI- to AIGND.
Greetings from Germany
Henrik
LV since v3.1
(3,587 Views)
Servus Henrik,
Vielen Dank for your advice. I would try it but before  that can you explain me a little bit more in detail about this problem or can you refer me some document regarding this problem because I am little bit new for this.
(3,582 Views)
How to measure voltage
and the documentation to your DAQ card ...
Henrik
LV since v3.1
(3,553 Views)
