virtual channel in max don' work whith pci6071
hello I configure 32 channels in max then when i test the first channel it' s ok.And when i test the second channel in max it don't work the light is red and for other channel is the same, if sommeone have a solution thank you.
(2,785 Views)
Can you be more precise. Which board do you have? Which driver?
Did you test your channels during the configuration? The led is red : is there an error message?
Regards
DD
(2,775 Views)
