voltage negative
 I use the DAQ NI6703 for output voltage negative by  using Matlab , I   used putsample function  putsample(ao,-1); however ,I cannot output the voltage negative.  I have tested the NI6703 by NI MAXmx, it fonctionne correctly.
this is my code :
%-------write to a NI 6703 DAQ device---------%
%-------------Initialization------------------%
%--------------analog Output------------------%
 ao=analogoutput('nidaq','Dev2');
 %-------Adding Channels----------------------%
 %-------Analog Output------------------------%
 addchannel(ao,0);
 %--------write data--------------------------%
 ao_value =-1;
 putsample(ao,ao_value);
 %----cleaning Up------%
 %waittilstop(ao,5)
 delete(ao);
 clear ao;
(4,740 Views)
Hi Leeou,
I am not familiar with Matlab but I think this forum can help you:
How do I use the PCI 6703 digital outputs with Matlab xpc
http://forums.ni.com/t5/Multifunction-DAQ/How-do-I-use-the-PCI-6703-digital-outputs-with-Matlab-xpc/...
Bye
Cindy
(4,699 Views)
Cindy,
I think Leeou is referring to the analog outputs, not the digital ouputs.
Lynn
(4,690 Views)
thank you for your response, I have fund my problem, and your information is alos useful for me.
(4,676 Views)
Proven Zealot,
yes I refer to  analog output, I fund  the problem is that I need to use the funtion:
ao.Channel(i).OutputRange=[-10 10];
thank you
leeou
(4,674 Views)
