Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
what if i connect a differential low impedance source with bias resistors
imfe
Member
12-23-2014
05:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Will i have an influence to the measured signal if i connect a differential low impedance source (10 Ohm) with 100k bias resistors?
0
Kudos
Message
1
of 2
(3,896 Views)
Reply
Re: what if i connect a differential low impedance source with bias resistors
Henrik_Volkers
Trusted Enthusiast
12-24-2014
07:25 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Yes, however you have to ask Kirchof and yourself wether it will matter you or not.
Greetings from Germany
Henrik
LV since v3.1
0
Kudos
Message
2
of 2
(3,868 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
