what is maximum read out speed of USB DAQ 6343
hello everyone,
we have new USB DAQ 6343.Its application note(or say characteristcs) says that it's sampling rate is 500K Sample/second.Now i need some clarification from you guys.I have to read digital data(serial or parallel). so plz tell me how much far I can go with this product for both ways.
thanks in advance,
(4,419 Views)
Unfortunatly I can't get the spec online
Error
You are not authorized to view this document
but you should have get it with your device 😉
However the datasheet is telling me something like 500kS/s aggregate (500kS/s / <number of channels read> ),  but up to 1MS/s for digital input. However you need to get the data into your PC. If you read one 8 bit port @1MS/s the USB should be able to handle the datastream.
Greetings from Germany
Henrik
LV since v3.1
(4,413 Views)
Accepted by topic author d_2014
While not for the 6343 here is a post that maybe can help about the X - Series cards
http://forums.ni.com/t5/Multifunction-DAQ/USB-6351-digital-streaming-output-rate/m-p/1506848/highlig...
Henrik
LV since v3.1
(4,408 Views)
thanks a lot
(4,387 Views)
