what is the minimum signal strength required for the 6211 DAQ card for the analog input
You seemed to have clicked the Post button before entering anything into the message body. Repost with details on what you want to know.
(3,015 Views)
As I understand your question; you want to know the minimum voltage that can be measured using DAQ 6211
It depends on the range of your input operation.
Voltage Range : -10V to 10V; Range Accuracy : 2.69mV.
Meaning you can measure upto as low as 2.69mV accurately.
Voltage Range : -200mV to 200mV; Range Accuracy : 0.088mV
Meaning you can measure upto as low as 0.088mV accurately.
thanks,
Ravi.
(2,995 Views)
