what's wrong to make program terminated after long term run?
I wrote a program to control 2 pumps, read one flowmeter, control a valve, and most importantly, turn on a heater by control how long a relay is on. Most of the controls were done in a while loop, and I set the loop time for 10s. I have tested the program for ~20hrs and the temperatures were monitored. It appears the program runs good in first 12hrs. The temperature reaches a steady state within probably 5hrs. Then there is a temperature drop after ~12hrs, apparently, something was wrong, either the heater was not working or the pump was not working (I set pump1 to work under a certain speed, pump2 at zero speed, valve was not open, flowmeter and pressure just reads a number). But the program still kept running for another hour, and next morning I saw a error message:
Error -50405 occurred at Heater PropContrl-sub.vi:Instance:3:1
Possible reason(s):
NI Platform Services: No transfer is in progress because the transfer was aborted by the client. The operation could not be completed as specified.
Task Name: _unnamedTask<59>
What could be wrong? Code is attached. It looks like the heater sub vi made the error. I also saw DAQ that reads the pressure was flashing after I stoped the program by closing the error message box, although I am not sure it was not performed properly or I have clicked by accident. Could be the memory was overwhelmed by the data? If so, how to clean the data?
Haorong
(2,832 Views)
Hi hrwang,
What is the form factor for your DAQ hardware? If you are using a USB device, the explanation and solution that you need could be found here.
Tunde S.
(2,806 Views)
