where is DAQmx_Val_InputTermCfg_Diff
Hello. I am using PXI-4461 and want to use differential input and output. However, when using
 DAQmxErrChk (DAQmxCreateAIVoltageChan(taskIn, AudioIn, "", DAQmx_Val_Cfg_Default, -1, 1, DAQmx_Val_Volts, NULL));
According to the documentation, the following options should be available:
DAQmx_Val_InputTermCfg_RSE
DAQmx_Val_InputTermCfg_NRSE
DAQmx_Val_InputTermCfg_PseudoDiff
only first constant is available in NIDAQmx.h, the other 4 are not defined.
MAX reports NI-DAQ to be version 8.3.0f3 and the file I am using is located in C:\Program Files\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include
Thank you
Roman
(3,770 Views)
Hi Roman,
The correct constants for C are DAQmx_Val_RSE, DAQmx_Val_NRSE, DAQmx_Val_Diff, and DAQmx_Val_PseudoDiff, which are defined in NIDAQmx.h. The ones you listed are for Visual Basic 6. What documentation were you looking at?
Brad Keryan
NI R&D
(3,755 Views)
Hi Brad,
thanks for the response. I was looking at NI-DAQmx C Reference Help -> Index -> DAQmxCreateAIVoltageChan.
Thank you
Roman
(3,750 Views)
Thanks Roman,
That is an error in the NI-DAQmx C Reference Help, and it will be fixed in the next version.
Brad
Message Edited by Brad K on 02-02-2007 03:49 PM
Brad Keryan
NI R&D
(3,749 Views)
