which type of adc and dac are used in m series pci 6281
can u tell me the type of adc used in pci 6281 mease it is successive approximation or other.
(3,608 Views)
Hello a1234,
The ADC used in the PCI-6281 is the Successive-Approximation Analog-to-Digital Converter (ADC).  See the following Knowledge base article to get more info on the ADC's used in different NI Data acquisition hardware.
I hope this helps!
Ima
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(3,578 Views)
Thank u for this imp information.
(3,560 Views)
You are welcome Smiley Happy
Ima
(3,553 Views)
To answer this question more precisely: The 16-bit M-Series PCI-6255, PCI-6259, and X-Series PCIe-6353 all use the Texas Instruments ADS8406 (ADS8406i). The 18-bit M-series cards (PCI-6281) use a similar ADC, probably the ADS8381.
Too bad that NI keeps overlooking the ADS1278, it would be perfect for an even better performing 24-bit, simultaneously sampling, 50kHz per input multifunction card. I am evaluating the ADS1278 presently, and it is clearly superior in my application.
(3,114 Views)
