while loop only runs once with datasocket read function
I am using a a data socket to break up some number crunching. The acquition computer isn't very power full and I am doing some fft and ppl work. Everything worked fine on one computer. Now I've datasocketed the process and am having issues. The computer running the read side well only run through the while loop once then it waits. While the write side runs normally. I get only one set of samples rather than a continuous signal. Does this have to do with the buffer size or some other feature of the data socket read I haven't setup?
(3,075 Views)
frontiergeo,
I hope you are doing well today! Check out this link and let me know if it helps:
Why Does My DataSocket Read Not Wait For the Timeout in LabVIEW?
Also, if you can attach an example VI showing an isolated version of your issue, that would be great!
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,059 Views)
