why has the acquisition of Signal from DAQ an error (breakpoint) in the time axis?
Hello, friends,
I have programmed to control a vibration system that is based on DAQ(NI917, NI9229, NI9263). All signals are from NI9229. when I save the data from the NI 9229 with the Write To Measurement.vi, then I find the problem in the data. The time axis for the data is not continuous, but broken. The breakpoint appear with a certain cycle, as shown in Bild "wrong time axis". It led to the signal error. i will show you a example by some charts in the appendix.
for example , DAQ Assistant.vi have the following Timing Setting: Acquistion Mode: Continuous Samples
        Samples to Read: 1K
        Rate (Hz): 25K
The acquired signal should be a continuous, as shown in chart "ideal signal (amplitude-number of measurement points)", but because the generated time axis is broken (chart "wrong time axis"), At the end, the generated signal is wrong, as shown in chart " worng sinal(amplitude-time)".
how can i solve the problem ?
major: Precision Mechanics and Microtechnology
(3,178 Views)
has somebody a idea?
(3,162 Views)
This looks like you have YX pair information for drawing.
 Have you tried using a Waveform datatype which contains onle the Y information and uses a constant delta t wit t0 offset to render the X axis?
Since it is organized in Chunks, I suppose the Cunksize is 1k like your DAQ Config specified.
Do you get the wrong Information out of the VI directly? could you post a example VI so we can see what your VI is doing there?
(3,151 Views)
