why it can not generate sine wave in test panels
I bought a PCI-6031E card and LabVIEW 7.0
EXPRESS for designing a set of virtual instrument. The hardware and software are installed
properly according to the manual, then we use test panels in the measurement & automation
explorer to test the functions of the card. All functions work well except the analog out
function. The card can output DC voltage, but it doesn�t work when we set the output mode
to sinewave generation and the error message it provides is error- 50400 (occurred at
daqmxcfg_DAQmx Start Task.vi). We try another test panels under traditional NI-DAQ devices,
it does not generate sine wave but send an error message of error 10805.Who can tell me whether there is something wrong w
ith the card or else.thank you in advance
(3,161 Views)
Based on the 10805 error code, I would suggest using a slower update rate for the analog output. This card can update the outputs at 100 kHz, which in the test panel may mean a maximum sine frequency of 100 Hz. The test panel uses 1000 samples per sine wave cycle, which you can adjust in you own application of course.
Christian L
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,161 Views)
Thank you for your suggestion.We have tried to run our program under different sampling rate.But all failed with the same error message error 10805.We suspect that there is a physical failure with the card.The card can not pass the default test in test panels,how can it run other program?
(3,161 Views)
Hi:
To further troubleshoot the card, it will be beneficial if you can test the card in a different computer and see if you get similar results.
Bharat Sandhu
Penny
(3,161 Views)
