windows 2000 AT-MIO-16XE-50
I'm wondering if anyone has experience using an AT-MIO-16XE-50 board in a wondows 2000 machine. Currently I use it in a widows 95 machine but I would like to move it to a 2000 machine. Are there any problems?
(3,078 Views)
Hello;
You shouldn't have no problems on working with that board on Windows 2000. Just make sure to upgrade the NI-DAQ driver to a version that supports the W2000 OS. I suggest you to uninstall whatever version you have now, download the latest version available at www.ni.com (version 6.9.3), install that version and follow the installation procedure for that hardware.
Hope this helps.
Filipe A.
(3,078 Views)
I would like to use the same type of DAQ card (AT-MIO-16XE-50)  with windows XP. I was wondering if there is any compatibility issue with that or not.
Any advice will be greatly acknowledged.
Cheers,
(2,696 Views)
