windows 7 6210
Hi all
I bought a laptop  with windows7 starter specialy for a certain application in the field
i needed a 6210
now what ever i do i cannot have daqmx   running even not version 9.02  als older version i get a message not compatible with this windows version
what to do?
(3,779 Views)
You will need to use a supported OS. Windows 7 starter is not.
(3,772 Views)
Accepted by topic author cees10
We are investigating the possibility of adding support for Windows 7 Starter Edition.
Hope this helps!
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,768 Views)
