windows xp
I have a pci6032E and my windows xp finds a new hardware but drivers versions 6.9.2 6.9.3 makes an error.
(2,744 Views)
Xavigonzalvo,
What is the error message that the nidaq 6.9.2 or 6.9.3 returns? It will help everyone here in the Discussions Forum.
L Aguila
(2,744 Views)
Hello;
The first thing you need to make sure is that only one version of the NI-DAQ driver is installed on your machine.
The best way to go about that now is to completely uninstall all NI Software you have there, and install only one version of the driver. After that, test the board on MAX Test Panel. In case the board is working properly, then you can go ahead and install the other Softwares you had, but always make sure that only one copy of NI-DAQ is installed at any given time.
Hope this helps.
Filipe A.
(2,744 Views)
