with matlab DAQ change frequency while continously outputing a sine wave?
I have an NI USB-6351 DAQ and I can continuously generate a signal. I need to be able to continuously generate a signal and change the frequency when desired, while still generating a signal. I have not been able to figure out how to change the frequency without shutting down the output first. This is the code I use to continuously generate the data:
function [source, lh] = daqWvformControl(freq, signalVoltPk, squareWv, sampleRate, Dur) source = daq.createSession('ni');
source.IsContinuous = true;
source.addAnalogOutputChannel('Dev1', 0, 'Voltage');
source.Rate = sampleRate; %in Hz
Npts = round(Dur*source.Rate);
x = (0:(Npts-1))/source.Rate;
data = signalVoltPk*sin(freq*2*pi*x); data=data(:);
if squareWv == 1;     data(data < 0) = - signalVoltPk; % Convert sin wave to square wave
data(data > 0) = signalVoltPk;
end
source.queueOutputData(data);
lh = source.addlistener('DataRequired', @(src, event)src.queueOutputData(data));
source.startBackground();
I know it is possible to continously generate the sine wave and also change the frequency of the output signal from the LABVIEW  forums, but I have not found the method with matlab and I don't have labview..... I'd think it is something in changing the queueOutputData, but I can't seem to get that to work... I also need to do it with amplitude, but I imagine the methods will be related.
Thanks for the help
(3,428 Views)
Hi MSUS,
You can post this to the MATLAB answers  site as you are using Data Acquisition Toolbox in MATLAB.
-Manisha
(3,422 Views)
