wrong duty cycle (pci 6014 and bnc2110)
I want to generate a square signal with labview 7.0, pci 6014 and bnc 2110. I attached my VI . The duty cycle works properly for instance for 10%, 20%, 30% (I suppose that it works because when I anlyse the signal: some pulse seams to not appear ) . BUT when I change the duty cycle constant to 15%: the output is again 20% and not 15%. It's the same case for 17%, 18%....
I really need to create square signal with a perfect duty cycle.
Do you know where is the problem?
Thank you
labview 7.0
(3,395 Views)
Do I need to use Digital and timing I/O to have the most precise signal?
(I want to generate a 100hz signal)
labview 7.0
(3,390 Views)
In the first message there is not smiley.. I wanted to say that some pulse (high level) are missing.
labview 7.0
(3,375 Views)
I found the problem for missing pulse: it's the while loop. I delete it and add more samples.
The duty cycle works now due to the precision of the "simulate signal"
labview 7.0
(3,362 Views)
Message Edité par ramiral le 08-25-2005 08:21 AM
labview 7.0
(3,353 Views)
