zero voltage AI is not zero
when check test panels, I should read zero volts, but I am obtaining ~0.19v
(2,609 Views)
I do not have information regarding your card.
There is a facility for most DAQ Cards to self calibrate the device. Have you performed this operation if it is available?
Can you supply information regarding your card.
Regards
Steven Bird
(2,609 Views)
