Name
SNR
Included
LabVIEW Custom Instrument, Test Circuit
Compatibility
Multisim 11.x, Multisim 12.x
Description
You can evaluate the Signal to Noise Ratio at the output of your filter, amplifier, or mixer using a new SNR instrument as in the example circuit below. The example also uses the Noise Source instrument which can be found under the Signal Generator area of application from the Documents section.
Instrument for Multisim 11 and 12.0 download
Instrument for Multisim 12.0.1 download
Test Circuit
