Multisim Custom Simulation Analyses and Instruments Documents
Formula Signal Generator
Name
Formula Simple
Included
LabVIEW Custom Instrument
Compatibility
Multisim 11.x, Multisim 12.x
Description
     This signal generator is made for you to input complex expressions into a formula generator to output a desired  signal. If you are looking to test very specific waves or signals generated through mathematical functions for design testing and verification then the versatility of this VI for complex equations is what you need. You can use sample rate, frequency, amplitude and offset to create a wave to output from the instrument. For a full syntax on the Formula Signal Generator, please see the readme in the attachments section.
Instrument for Multisim 11 and 12.0 download
Instrument for Multisim 12.0.1 download
Note: If you are looking for a more simplified version of this VI please refer to Expression Signal Generator.
Miguel V
Contributors
