Multisim Custom Simulation Analyses and Instruments Documents
Waveform Calculator
Name
Waveform Calculator
Included
LabVIEW Custom Instrument
Compatibility
Multisim 11.x, Multisim 12.x
Description
     The waveform calculator can help you visualize signal modulation through arithmetic. The calculator has a separate viewing tab for signal analysis and the options to set smapling rate, size and interpolation method of the data. It will generate a resulting wave depending on your input expression and can take inputs of up to 4 different signals. Not only that, but it also functions as a regular calculator.
Instrument for Multisim 11 and 12 download
Miguel V
Contributors
