Hello, thanks for response
There is something about MS wire color scheme
Technically there are a lot of colors and tints available but practically to distinguish there are no more than 7 or 8 colors.
My suggestion is to use 2 color scheme – 1 color for wire and 2nd for strip.
In this case wire would be clearly visible with from 7*7 to 8*8 color combinations
with hope it helps
thanks a lot
Michael
