Ultiboard's single interface for layout and simulation with ultiboard's new parts spice model library and all the test instuments from multisim
Status: New
by Member dubmaster 02-19-2016 12:18 PM - edited 02-19-2016 12:22 PM
Set up ultiboard with all the test instruments and spice models  like multisim. You would do away with multisim and develope a single interface within ultiboard to simulate and design and layout ....
You would place the parts on the board, i.e. transformer ,diode caps wire them  like you do in multisim, place test instrument ...
This would save time because you would place parts where the are to be , have the ability to run simulation within ultiboard  single interface ..
Place a 741 op amp from the ultiboard library that would have the foot print and spice model with in ultiboard , place the feed back resistor ..
It kinda make no sense to lay out twice , once in multisim , then ultiboard , the single interface would be king..
The New symbol
The Scientist
