Multisim and Ultiboard
0xE06D7363 Error Cosimulation
I am writing this post because I´m having a problem when launching a LabVIEW and Multisim cosimulation.
The error I get appears when LabVIEW tries to simulate the circuit I have implemented. I had the same versions installed in a previous PC but I had to install all the software again because we have renewed all the equipment. The circuits implemented in the old PC work fine but the ones constructed in this new PC don´t work at all.
The error occurs in the LabVIEW environment when running the simulation and it shows the next message:
Exception: C++ Exception (0xE06D7363) at EIP=0x7508C42D
Version: 13.0.995.0
A local copy of the error report was saved in this location: LabVIEW Data Folder.
Report ID: 836322a2-d32c-44d0-9cf1-12af14570852
The report contains:
<Version>2.0</Version>
<Autosend>False</Autosend>
<Email>
</Email>
<FileAttached>
</FileAttached>
<Comments>
</Comments>
It seems to be a blank document.
Another log document shows the next:
#Date: jue, 31 de jul de 2014 16:28:14
#OSName: Windows 7 Professional Service Pack 1
#OSVers: 6.1
#OSBuild: 7601
#AppName: multisim
#Version: 12.0.1f7 32-bit
#AppKind: AppLib
#LabVIEW Base Address: 0x30000000
<DEBUG_OUTPUT>
31/07/2014 16:28:14.558
Crash 0x0: Crash caught by NIER
File Unknown(0) : Crash 0x0: Crash caught by NIER
minidump id: e1605ddf-c26d-4187-9328-113ec2f270c6
ExceptionCode: 0xE06D7363à    N
</DEBUG_OUTPUT>
0x30729094 - lvrt <unknown> + 0
0x30729418 - lvrt <unknown> + 0
0x765C0303 - kernel32 <unknown> + 0
0x773574FF - ntdll <unknown> + 0
0x77319F45 - ntdll <unknown> + 0
0x00000000 - <unknown> <unknown> + 0
Furthermore, Labview exhibits another error message box telling me:
Error -2367 occurred at External Model in [SIM] - PLL.vi/Control & Simulation Loop
Possible reason(s):
Control Design and Simulation:  The shared library corresponding to the external model returned an error.
Launching Multisim was unsuccessful. (L404)
I think this second error is because of the Multisim crash.
I have looked for the error, or the solution but I have not found any post regarding them. The software I am using is the LabVIEW 2013 and Multisim v13.
Could anyone help me with the with the error? I have tried to uninstall them several times but the error is always the same.
Thank you in advance.
Jose Miguel
(10,766 Views)
In addition, I have found the next error information inspecting the windows error log (attached picture named error-multisim.png).
Jose Miguel
<?x
(10,729 Views)
Hi Jose,did you get the answer of quesion you have posted.I didn't  see any reply to this question, you have posted about more tham a year ago.I am curious did you able to solve because i am facing the problem and getting the same error.I have tried to rectify this fail but so far i have failed.If you have any suggestion,help me out.
(9,871 Views)
The same happens to me, using Multisim 14 and LabVIEW 2014 SP1:
Multisim cosimulation crash
Any ideas, anyone, on how to solve this problem?
(9,533 Views)
My particular problem, having to do with some kind of file paths issue, will apparently be solved in the 14.0 maintenance relase of Multisim/LabVIEW.
(9,358 Views)
我来解答一下,花了几天时间找到原因。希望能够帮到你!
我遇到的C++ Exception(0xE06D7363)
贴上这个故障的源码(运行后,内存持续上升,最后报错):
原因:“产生用户事件”循环里没有加延时
(3,298 Views)
