 tourmansasurai
			tourmansasurai
			06-02-2010 06:12 PM
I'll appreciate any information that will be useful for that purpose.
 Andrew.J
			Andrew.J
			06-04-2010 12:38 AM
Hi
DF below telling HOW to use Keypad.
The example is good.
http://forums.ni.com/ni/board/message?board.id=370&message.id=6959&query.id=6833775#M6959
06-05-2010 08:38 AM
Thank you Andrew for your response.
The MCU example seems to be a modern solution for simulating a calculator.
However, I'd like to use only a conventional TTL or CMOS logic-ICs for simulating a calculator using a KEYPAD. This is just for an educational purpose.
Attached file is my latest circuit which Input is done by a simple switches for decimal inputs: It can add only single figures and the maximum effective sum value is 9.
"74147" is 10-Line to 4-Line BCD Encoder that converts the decimal input to a BCD output. "74181" is an Arithmetic Logic Units.
My plan is to replace the switches & 74147s to a NUMERIC_KEYPAD & BCD encoder logic ICs or circuits for demonstrating the calculator more familiar.
I'll wait for additional information from anyone.
 faizan88
			faizan88
			06-14-2023 04:15 PM
sir can you please tell me how do i make 2 digit calculator? using encoder shift registers adders and decioder i work on 1 digit calculator but dont on 2 digit kindly let me know
