Multisim and Ultiboard
2367 error
hi,
i got error as 2367 while running the vi in the labview2012,which i was converted from multisim2012 design into labview2012 the error was "TIME STEP TOO SMALL".could you please suggest solution.go through the bellow attachments.
 thanks &regards
(4,402 Views)
In your control loop in LabVIEW, there are various options you set on the top-left menus. Try changing the tolerance values (to a higher value, so instead of e-12 make it e-8) to see if that affects your circuit. Try playing with these values a bit. When the time step is too small, usually this has to do with the precision and calculations being done to produce an answer so relieving these restrictions a bit can avoid overflows and other problems.
Kind regards,
Miguel V
(4,338 Views)
hi Miguel,
thanks for your quick reply, the suggestion you have given i was applied earlier the same but there was no improvement in the response so please  suggest another option to overcome the error.
Thanks&Regards
(4,328 Views)
