Multisim and Ultiboard
2N2905A COMPONENT
Hello, I need a help. Cant find the component 2N2905A in Multisim. Is there any way or step by step to create this component?
(1,362 Views)
You can use a model from any spice compatible simulator, as OrCAD. You can download the .cir file and then import it in the Part Wizard.
Also you can select packages and such.
Also Note that 2n2905 is actually in the component library in the bjt_pnp family
(1,281 Views)
