Multisim and Ultiboard
2k8ram
Hello.
I'm doing some experiments with RAM in Multisim 9. I've readed that the component 2k8ram is the only memory that works in the simulation, but I can't get it work.
I'm doing it right, I've got books about static rams and I've tryed out several circuit designs, but it doesn't work.
Any suggestion?
Thanks a lot! Best regards.
(3,945 Views)
I replied to the other thread before I noticed you had started a new one. Here is the repost:
I wanted to do a demo of how RAM worked so the file attached is what I came up with. I had my students save the 4 bit gray code sequence in the RAM and step through it. Once you stop the simulator the content of the RAM is cleared so it also shows how volatile memory works.
Hopefully it's helpful to you.
(3,922 Views)
