Multisim and Ultiboard
4 bit counter
Hi everybody
I am trying to make simple 4 bit counter (not synchronous or Asyn) using standard 8 bit counter(means xxxx1111 would maximum count) can anyone help me
Thanks in advance.....
(5,572 Views)
In Multisim 12, go to File -> Open Samples. In the samples folder, you will see an Up-DownCounter.ms12 file. This is a 4-bit up down counter using flip flops.
Hope this helps.
Tayyab R,
National Instruments.
(5,567 Views)
Many thanks sir but I am using multisim 11 and I was able to perform that particular operation using 8 bit counter
(5,562 Views)
