Multisim and Ultiboard
4033 IC?
Hi all,
Just a quick and relatively simple question. Where can i find a 4033 IC in the parts list. What i'm after is a
decade (divide by ten) counter with 7 segment decoded output(synchronous). Or an equivalent.
If anyone can help it would be great. And if it is a different type to the 4033 then perhaps a simple explanation
of the connections when copmpared to the 4033 might be needed please  🙂  The model or parts code i have is
CD4033BE   H9922BQWN
Many Thanks
Rob
(5,757 Views)
Hi Rob
Unfortunately the part you require is not already in the Multisim database.
Multisim has the functionality of users being able to define their own components.
There is a wizard which is easily the most straight forward way of adding a custom component.
This can be found in tools under component wizard. It will give you a step by step guide to create a component. Which you can then use in your designs.
Regards
Robert
National Instruments UK & Ireland
(5,720 Views)
