Multisim and Ultiboard
4520BP in multisim 10
I have multisim 10 but I could not get 4bit dual counter (4520BP) as the one below in the picture:
All what I get is 4520BP_10v and 15v, and pin 2 is not similar to the one above?
So, how can I get this compnent??
(3,415 Views)
Hi Nawras,
Thank you for contacting National Instruments. I have been looking at this issue for you. Pin 2 seems to be showing that this is an inverted pin i.e. if the input is low, then the chip is enabled. I have looked at Multisim 11.0 and found that we offer 4 different chips like this in a variety of different operating voltages.
I would suggest that all you need to do is invert your signal within multisim to gain the same performance as you desire.
Many thanks,
Andrew McLennan
(3,383 Views)
