Multisim and Ultiboard
5-bit binary in 2 seven segment displays?
How to display a 5-bit binary in 2 seven segment displays using gates or components available in multisim?
(6,637 Views)
It seems you already have a working file. The way a seven segment display works is by lighting each individual light of a the display (there's 7 lights for number 8 for example). You can use a driver or figure out a logic using digital gates. If oyu need information on this, there are lots of examples on the web and youtube. There's also samples in the Multisim samples folder involving seven segment displays that you can see.
Kind regards,
Miguel V
(6,610 Views)
Thanks for sharing a great post.
(6,596 Views)
