Multisim and Ultiboard
74LS163D model symbol pins map incorrect
here is the correct symbol(figure 1),but in multisim 11, 74LS163D symbol it's wrong,74LS163N symboe is correct(figure2)
(3,624 Views)
Thank you for the feedback, the 74LS163N is footprint mapping is wrong and I will let R&D know about this.
To fix it on your end, double click on the component and then select Edit Component in db>>Footprint, make the change in the mapping table, click OK and you save the component to the User database.
Tien P.
(3,581 Views)
