Multisim and Ultiboard
AC analysis bode plot export
I've recently ran some AC analysis of a system generated in Multisim however I'm needing to run the graph data collected through Matlab for plotting.  So far I can only manage to export just the magnitude vs frequency plot data as a text file.  Is there any way of exporting both magnitude and phase plot data from the grapher?
Many thanks,
Robert James
(6,627 Views)
Hi Robert,
The easiest way is to export data from both plots to Excel, and in Excel you can copy/paste data from one spreadsheet to another very easy. In grapher view, click on the plot and little red arrow to the left of the y-axis name this arrow indicates which graph is active. When you export data to Excel, data from the active plot will be exported.
Tien P.
(6,590 Views)
