Multisim and Ultiboard
AC analysis+cursors
Hello everybody,small AC analysis question.
I would like to simulate my AC analysis like I have it on the bode plotter, between Uout and Uin, a 3x amplification.
The results I get on the AC analysis differ quite a bit, I think it compares it with Uout and ground.
Also, how do I add more cursors/markers ? Two just is not enough.
Using MultiSim 12
Thank you for reading
(4,108 Views)
Hello Scrubber
Actually you just need to add an expression (in this case Vout/Vin) I attached two files that explain that process.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH7bCAG&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YG18CAG&l=en-US
Regarding with the cursors question. When clicked on run in the AC Analysis you just can use two cursors, however I would like to know why you need to use more cursors?
Regards
(4,085 Views)
